Aller au contenu principal
Sony Handycam HDR-CX580V Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Handycam HDR-CX580V Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Motherboard Replacement: étape 2, image 1 de 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Motherboard Replacement, Recording Button: étape 3, image 1 de 3 Sony Handycam HDR-CX580V Motherboard Replacement, Recording Button: étape 3, image 2 de 3 Sony Handycam HDR-CX580V Motherboard Replacement, Recording Button: étape 3, image 3 de 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Motherboard Replacement: étape 4, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Motherboard Replacement: étape 5, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Motherboard Replacement: étape 6, image 1 de 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Motherboard Replacement: étape 7, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 7, image 2 de 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Motherboard Replacement: étape 8, image 1 de 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Motherboard Replacement: étape 9, image 1 de 3 Sony Handycam HDR-CX580V Motherboard Replacement: étape 9, image 2 de 3 Sony Handycam HDR-CX580V Motherboard Replacement: étape 9, image 3 de 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Motherboard Replacement: étape 10, image 1 de 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Motherboard Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Motherboard Replacement: étape 12, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 12, image 2 de 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Motherboard Replacement: étape 13, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Motherboard Replacement: étape 14, image 1 de 1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Motherboard Replacement: étape 15, image 1 de 1
    • You are now free to remove the recording button, as well as its connection strip.
  16. Sony Handycam HDR-CX580V Motherboard Replacement, Lens: étape 16, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
  17. Sony Handycam HDR-CX580V Motherboard Replacement: étape 17, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top near the lens.
  18. Sony Handycam HDR-CX580V Motherboard Replacement: étape 18, image 1 de 1
    • Carefully pop off the casing strip on the camera's left-hand side near the lens.
  19. Sony Handycam HDR-CX580V Motherboard Replacement: étape 19, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the casing strip.
  20. Sony Handycam HDR-CX580V Motherboard Replacement: étape 20, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 20, image 2 de 2
    • Carefully pull the lens cover and shutter assembly off of the front of the camera.
    • Do not pull the the wires out too strongly. Be sure to remove them from their base where they attach to the camera's body.
  21. Sony Handycam HDR-CX580V Motherboard Replacement: étape 21, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the lens shell.
  22. Sony Handycam HDR-CX580V Motherboard Replacement: étape 22, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 22, image 2 de 2
    • Carefully remove the lens from the body of the camera.
    • Make sure to avoid touching the lens itself directly in order to prevent scratches or dirtying.
  23. Sony Handycam HDR-CX580V Motherboard Replacement, Motherboard: étape 23, image 1 de 3 Sony Handycam HDR-CX580V Motherboard Replacement, Motherboard: étape 23, image 2 de 3 Sony Handycam HDR-CX580V Motherboard Replacement, Motherboard: étape 23, image 3 de 3
    • To begin removing the metal casing, use the Phillips #00 head to remove the following 5.5mm screws.
  24. Sony Handycam HDR-CX580V Motherboard Replacement: étape 24, image 1 de 3 Sony Handycam HDR-CX580V Motherboard Replacement: étape 24, image 2 de 3 Sony Handycam HDR-CX580V Motherboard Replacement: étape 24, image 3 de 3
    • Hold the camera so you can see the motherboard on its bottom.
    • With a pair of straight tweezers, carefully remove the hanging panel by the following bundled cable connectors and ribbon cable connector attached to the motherboard.
    • At this point, the side panel that has been hanging should now be removed and placed to the side.
  25. Sony Handycam HDR-CX580V Motherboard Replacement: étape 25, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 25, image 2 de 2
    • The camcorder's chip and part of the motherboard should naturally fall off at this point and should carefully be removed and placed to the side.
  26. Sony Handycam HDR-CX580V Motherboard Replacement: étape 26, image 1 de 1
    • Use the Phillips #00 head to remove the following 5.5mm screws from the side of the motherboard.
  27. Sony Handycam HDR-CX580V Motherboard Replacement: étape 27, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 27, image 2 de 2
    • Use the Phillips #00 head to remove the following 5.5mm screws and remove the lens compartment by carefully pulling it out of the metal casing.
    • Do not pull the lens compartment too hard.
  28. Sony Handycam HDR-CX580V Motherboard Replacement: étape 28, image 1 de 1
    • Use the Phillips #00 head to remove the 5.5mm screw inside the metal casing.
    • This screw may be hidden under the black strip inside the camera's body. If so, carefully move it aside with the pair of straight tweezers.
  29. Sony Handycam HDR-CX580V Motherboard Replacement: étape 29, image 1 de 1
    • Using a pair of tweezers, remove the ribbon cable connector attached to the metal casing and the motherboard.
  30. Sony Handycam HDR-CX580V Motherboard Replacement: étape 30, image 1 de 2 Sony Handycam HDR-CX580V Motherboard Replacement: étape 30, image 2 de 2
    • Using a pair of tweezers, remove the following ribbon cable connectors to remove the motherboard from the camcorder.
  31. Sony Handycam HDR-CX580V Motherboard Replacement: étape 31, image 1 de 1
    • Carefully remove the motherboard by hand.
    • It should be relatively easy to remove if everything is removed properly.
Ligne d'arrivée
Joyelle Woodson
Membre depuis le 03/21/17
270 Réputation
2 tutoriels rédigés
Équipe
Texas Tech, Team S46-G5, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G5, Bennett Spring 2017
TTU-BENNETT-S17S46G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 13
Total : 840
