Aller au contenu principal
Sony XAV-AX100 Volume Knob Replacement
Ce dont vous avez besoin
  1. Sony XAV-AX100 Volume Knob Replacement, USB Cable: étape 1, image 1 de 3 Sony XAV-AX100 Volume Knob Replacement, USB Cable: étape 1, image 2 de 3 Sony XAV-AX100 Volume Knob Replacement, USB Cable: étape 1, image 3 de 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Volume Knob Replacement: étape 2, image 1 de 2 Sony XAV-AX100 Volume Knob Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Volume Knob Replacement: étape 3, image 1 de 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Volume Knob Replacement: étape 4, image 1 de 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Volume Knob Replacement: étape 5, image 1 de 3 Sony XAV-AX100 Volume Knob Replacement: étape 5, image 2 de 3 Sony XAV-AX100 Volume Knob Replacement: étape 5, image 3 de 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Volume Knob Replacement, Motherboard: étape 6, image 1 de 2 Sony XAV-AX100 Volume Knob Replacement, Motherboard: étape 6, image 2 de 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Volume Knob Replacement: étape 7, image 1 de 3 Sony XAV-AX100 Volume Knob Replacement: étape 7, image 2 de 3 Sony XAV-AX100 Volume Knob Replacement: étape 7, image 3 de 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Volume Knob Replacement, Display: étape 8, image 1 de 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Volume Knob Replacement: étape 9, image 1 de 2 Sony XAV-AX100 Volume Knob Replacement: étape 9, image 2 de 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Volume Knob Replacement, Display Board: étape 10, image 1 de 3 Sony XAV-AX100 Volume Knob Replacement, Display Board: étape 10, image 2 de 3 Sony XAV-AX100 Volume Knob Replacement, Display Board: étape 10, image 3 de 3
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Volume Knob Replacement: étape 11, image 1 de 1
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Volume Knob Replacement: étape 12, image 1 de 1
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Volume Knob Replacement: étape 13, image 1 de 1
    • Use a plastic opening tool to remove the display board from the radio.
  14. Sony XAV-AX100 Volume Knob Replacement, Volume Knob: étape 14, image 1 de 3 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: étape 14, image 2 de 3 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: étape 14, image 3 de 3
    • Remove the silver knob cover by pulling upwards on it.
    • Remove the plastic face plate.
    • Pull off the black knob.
Abdulaziz Redha
Membre depuis le 02/22/18
741 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 23
Total : 2,771
