Aller au contenu principal
Sony Xperia XA1 Audio Jack Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: étape 1, image 1 de 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: étape 1, image 2 de 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: étape 1, image 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: étape 2, image 1 de 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: étape 2, image 2 de 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: étape 2, image 3 de 3
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: étape 3, image 1 de 3 Sony Xperia XA1 Audio Jack Replacement: étape 3, image 2 de 3 Sony Xperia XA1 Audio Jack Replacement: étape 3, image 3 de 3
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: étape 4, image 1 de 3 Sony Xperia XA1 Audio Jack Replacement: étape 4, image 2 de 3 Sony Xperia XA1 Audio Jack Replacement: étape 4, image 3 de 3
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
Lindsey Taysom
Membre depuis le 02/14/23
205 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 145
