Aller au contenu principal
Sony Xperia XA1 Rear Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: étape 1, image 1 de 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: étape 1, image 2 de 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: étape 1, image 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: étape 2, image 1 de 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: étape 2, image 2 de 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: étape 2, image 3 de 3
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: étape 3, image 1 de 3 Sony Xperia XA1 Rear Camera Replacement: étape 3, image 2 de 3 Sony Xperia XA1 Rear Camera Replacement: étape 3, image 3 de 3
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: étape 4, image 1 de 3 Sony Xperia XA1 Rear Camera Replacement: étape 4, image 2 de 3 Sony Xperia XA1 Rear Camera Replacement: étape 4, image 3 de 3
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
sebastianh034
Membre depuis le 02/14/23
253 Réputation
3 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 5
Total : 128
