Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony Xperia XA1 USB-C Module Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: étape 1, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: étape 1, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: étape 1, image 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
    Demander à FixBot
  2. Sony Xperia XA1 USB-C Module Replacement, Speaker: étape 2, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: étape 2, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: étape 2, image 3 de 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
    Demander à FixBot
  3. Sony Xperia XA1 USB-C Module Replacement: étape 3, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 3, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 3, image 3 de 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
    Demander à FixBot
  4. Sony Xperia XA1 USB-C Module Replacement: étape 4, image 1 de 2 Sony Xperia XA1 USB-C Module Replacement: étape 4, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
    Demander à FixBot
  5. Sony Xperia XA1 USB-C Module Replacement: étape 5, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 5, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 5, image 3 de 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
    Demander à FixBot
  6. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: étape 6, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: étape 6, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: étape 6, image 3 de 3
    • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
    • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
    Demander à FixBot
  7. Sony Xperia XA1 USB-C Module Replacement: étape 7, image 1 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 7, image 2 de 3 Sony Xperia XA1 USB-C Module Replacement: étape 7, image 3 de 3
    • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
    • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
    Demander à FixBot
sebastianh034
Membre depuis le 02/14/23
253 Réputation
3 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G4
3 membres
7 tutoriels rédigés
1 commentaire de tutoriel
thanks a lot, super clear, done everything in ~10 minutes
Eugene - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 32
Total : 753
