Aller au contenu principal
Sony Xperia XA2 Ultra Vibration Motor Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA2 Ultra Vibration Motor Replacement, Rear Cover: étape 1, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement, Rear Cover: étape 1, image 2 de 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 2, image 1 de 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 3, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 3, image 2 de 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 4, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 4, image 2 de 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 5, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 5, image 2 de 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 6, image 1 de 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Vibration Motor Replacement, Speaker: étape 7, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement, Speaker: étape 7, image 2 de 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  8. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 8, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 8, image 2 de 2
    • Using an iFixit opening tool, pry and remove the speaker.
  9. Sony Xperia XA2 Ultra Vibration Motor Replacement, Charging Port: étape 9, image 1 de 1
    • Using the iFixit opening tool, disconnect the flex cable.
  10. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 10, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 10, image 2 de 2
    • Remove both the black and white antenna cables using the Jimmy.
  11. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 11, image 1 de 1
    • Remove the vibration flex cable with the Jimmy.
  12. Sony Xperia XA2 Ultra Vibration Motor Replacement: étape 12, image 1 de 1
    • Using the Jimmy and the iFixit opening tool, remove the charging port.
  13. Sony Xperia XA2 Ultra Vibration Motor Replacement, Vibration Motor: étape 13, image 1 de 2 Sony Xperia XA2 Ultra Vibration Motor Replacement, Vibration Motor: étape 13, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, pry underneath the vibration motor and pull from its place.
    • There is an adhesive underneath it so removing it may take a bit of work.
Alyssa Bayles
Membre depuis le 09/27/22
819 Réputation
8 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, Randazzo Fall 2023 Membre de l'équipe Utah Tech University, Team 1-1, Randazzo Fall 2023
UTAHTECH-RANDAZZO-F23S1G1
1 membre
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 6
Total : 82
