Aller au contenu principal
Sony Xperia XZ Premium Frame Replacement
Ce dont vous avez besoin
  1. Sony Xperia XZ Premium Frame Replacement, Back Panel: étape 1, image 1 de 1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Frame Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Frame Replacement: étape 3, image 1 de 1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Frame Replacement, Frame: étape 4, image 1 de 1
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Sony Xperia XZ Premium Frame Replacement: étape 5, image 1 de 2 Sony Xperia XZ Premium Frame Replacement: étape 5, image 2 de 2
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Sony Xperia XZ Premium Frame Replacement: étape 6, image 1 de 1
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Sony Xperia XZ Premium Frame Replacement: étape 7, image 1 de 1
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Sony Xperia XZ Premium Frame Replacement: étape 8, image 1 de 1
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. Sony Xperia XZ Premium Frame Replacement: étape 9, image 1 de 1
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  10. Sony Xperia XZ Premium Frame Replacement: étape 10, image 1 de 1
    • Place the spudger under the top right frame piece and lift to loosen it.
  11. Sony Xperia XZ Premium Frame Replacement: étape 11, image 1 de 1
    • Grab hold of the top right frame piece with your fingers and lift.
3 autres ont terminé cette réparation.
Gelene Amog
Membre depuis le 04/18/18
1 165 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S18-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 33
Total : 2,965
