Aller au contenu principal
Sony Xperia Z1s Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Xperia Z1s Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Motherboard Replacement: étape 2, image 1 de 1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Motherboard Replacement: étape 3, image 1 de 1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Motherboard Replacement: étape 4, image 1 de 1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Motherboard Replacement: étape 5, image 1 de 1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Motherboard Replacement: étape 7, image 1 de 1
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Motherboard Replacement: étape 8, image 1 de 1
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Motherboard Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Motherboard Replacement: étape 10, image 1 de 1
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
Matthew Klengson
Membre depuis le 09/30/21
324 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 4-4, Hunter Fall 2021 Membre de l'équipe Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 169
