Introduction
Use this guide to replace the LCD & Digitizer of your Sony Xperia Z3.
To reassemble the device, follow this guide in reverse order and apply new adhesive where needed.
Ce dont vous avez besoin
Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
Lift up the back cover with a suction handle and put an opening pick in the gap.
Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
Unplug the battery flex connector.
Use a tweezer to gently pull off the adhesive strip on the bottom part of the battery.
Use a spudger to gently slide beneath the display flex cable and lift it up.
After loosening the adhesive in the lower area of your phone with an opening pick, insert an other opening pick approximately 1/16 of an inch and slide it along both sides of the phone to sparate the display from the frame.
After loosening all the adhesive beneath the display twist the opening pick in the lower end of your phone a little bit to lift up the display.
37 autres ont terminé cette réparation.
7 commentaires
What website is best to obtain a genuine screen and back from?
The back cover won’t fall off Josua but I would definitely recommend new adhesive!
But only for the phone to be waterproof? Because mine is definitely not waterproof anymore.. So I think this wouldn’t make any difference.
Josua -
In our case the back cover just held semi tight to the phone assembly without new adhesive. It could happen that the back cover falls off, when you pull the phone out of your pocket or you drop it. New adhesive also protects your phone from dust which can cause overheating.
