Aller au contenu principal
Sony a7 Rear Disassembly Replacement
Ce dont vous avez besoin
  1. Sony a7 Rear Disassembly  Replacement, Rear Disassembly: étape 1, image 1 de 1
    • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
    • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
  2. Sony a7 Rear Disassembly  Replacement: étape 2, image 1 de 3 Sony a7 Rear Disassembly  Replacement: étape 2, image 2 de 3 Sony a7 Rear Disassembly  Replacement: étape 2, image 3 de 3
    • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
  3. Sony a7 Rear Disassembly  Replacement: étape 3, image 1 de 1
    • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
  4. Sony a7 Rear Disassembly  Replacement: étape 4, image 1 de 2 Sony a7 Rear Disassembly  Replacement: étape 4, image 2 de 2
    • Remove the four M 1.5x2mm screws.
  5. Sony a7 Rear Disassembly  Replacement: étape 5, image 1 de 3 Sony a7 Rear Disassembly  Replacement: étape 5, image 2 de 3 Sony a7 Rear Disassembly  Replacement: étape 5, image 3 de 3
    • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
  6. Sony a7 Rear Disassembly  Replacement: étape 6, image 1 de 1
    • Using the blunt tweezers, remove the blue ribbon cable.
    • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
  7. Sony a7 Rear Disassembly  Replacement: étape 7, image 1 de 2 Sony a7 Rear Disassembly  Replacement: étape 7, image 2 de 2
    • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
  8. Sony a7 Rear Disassembly  Replacement: étape 8, image 1 de 3 Sony a7 Rear Disassembly  Replacement: étape 8, image 2 de 3 Sony a7 Rear Disassembly  Replacement: étape 8, image 3 de 3
    • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
  9. Sony a7 Rear Disassembly  Replacement: étape 9, image 1 de 1
    • Lift the metal plate and LCD screen away from the camera body.
  10. Sony a7 Rear Disassembly  Replacement: étape 10, image 1 de 1
    • Detach the amber ribbon cable from the motherboard.
9 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 116
Total : 5,822
