Aller au contenu principal
Spy Net Ultra Vision Goggles Microphone Replacement
Ce dont vous avez besoin
  1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: étape 1, image 1 de 1
    • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: étape 2, image 1 de 1
    • Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Un-solder the wires from the board using the soldering iron.
    • Need Help Soldering? Check out Comment souder et dessouder des connexions
  3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: étape 3, image 1 de 1
    • Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Un-solder the wires from the microphone using the soldering iron.
    • Remove the red and black wires from the device and solder on the replacement.
Justin Diehl
Membre depuis le 09/22/14
66 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 4-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 14
Total : 341
