Outils
Pièces
Aucune pièce spécifiée.
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
38 autre(s) ont terminé cette réparation.
3 commentaires
There are several versions of the Super Nintendo. Steps for my version are a bit different.
This seems to be a newer super nintendo. If you have one of the older ones, there will be a bit more screws but still basically the same steps.
It’s possible they may be referring to the European/Japanese version of the Super Nintendo/Super Famicom. Either that, or it’s one of the weird, misshapen “reskins”.
