Aller au contenu principal
System76 Serval WS Cooling Fan Replacement
Ce dont vous avez besoin
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 1
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: étape 2, image 1 de 2 System76 Serval WS Cooling Fan Replacement: étape 2, image 2 de 2
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: étape 3, image 1 de 1
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: étape 4, image 1 de 2 System76 Serval WS Cooling Fan Replacement: étape 4, image 2 de 2
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Oliver Anderson
Membre depuis le 03/26/19
289 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G4, Valliere Spring 2019
UMASSD-VALLIERE-S19S1G4
4 membres
3 tutoriels rédigés
Un commentaire
What model of fan would one buy to replace this?
CrustyTrombone - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 621
