Aller au contenu principal
Pour réparer ensemble - Je crée un compte
TicWatchPro Battery Replacement
Ce dont vous avez besoin
  1. TicWatchPro Battery Replacement, Unfasten the screws: étape 1, image 1 de 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. TicWatchPro Battery Replacement, Open the watch: étape 2, image 1 de 2 TicWatchPro Battery Replacement, Open the watch: étape 2, image 2 de 2
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. TicWatchPro Battery Replacement, Disconnect the sensor cable: étape 3, image 1 de 2 TicWatchPro Battery Replacement, Disconnect the sensor cable: étape 3, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. TicWatchPro Battery Replacement, Remove the back cover: étape 4, image 1 de 1
    • Remove the back cover.
  5. TicWatchPro Battery Replacement, Core Assembly Removal: étape 5, image 1 de 1
    • Remove the three 3.7 mm-long Phillips #00 screws.
  6. TicWatchPro Battery Replacement: étape 6, image 1 de 3 TicWatchPro Battery Replacement: étape 6, image 2 de 3 TicWatchPro Battery Replacement: étape 6, image 3 de 3
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
  7. TicWatchPro Battery Replacement: étape 7, image 1 de 2 TicWatchPro Battery Replacement: étape 7, image 2 de 2
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
  8. TicWatchPro Battery Replacement: étape 8, image 1 de 2 TicWatchPro Battery Replacement: étape 8, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
  9. TicWatchPro Battery Replacement: étape 9, image 1 de 2 TicWatchPro Battery Replacement: étape 9, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
  10. TicWatchPro Battery Replacement: étape 10, image 1 de 1
    • Remove the core assembly.
  11. TicWatchPro Battery Replacement, Remove the motherboard screw: étape 11, image 1 de 1
    • Use a Phillips driver to remove the screw securing the motherboard.
  12. TicWatchPro Battery Replacement: étape 12, image 1 de 2 TicWatchPro Battery Replacement: étape 12, image 2 de 2
    • The motherboard is held tightly in place by small, fragile plastic clips. Be very careful as you pry during the following procedure.
    • Use the flat end of a spudger or your fingernail to carefully bend the plastic clips around the motherboard to the side in order to free the motherboard.
    • Repeat this procedure for all plastic clips around the motherboard.
    • Note that there are also clips underneath the rubber pads covering the two side buttons.
    • Don't try to remove the motherboard all the way yet. It is still connected to the battery.
  13. TicWatchPro Battery Replacement: étape 13, image 1 de 2 TicWatchPro Battery Replacement: étape 13, image 2 de 2
    • Carefully lift the motherboard assembly to free it from any remaining plastic clips.
  14. TicWatchPro Battery Replacement: étape 14, image 1 de 2 TicWatchPro Battery Replacement: étape 14, image 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  15. TicWatchPro Battery Replacement: étape 15, image 1 de 1
    • Apply a heated iOpener to the back of the white plastic frame for at least two minutes to loosen the adhesive beneath the battery.
  16. TicWatchPro Battery Replacement: étape 16, image 1 de 3 TicWatchPro Battery Replacement: étape 16, image 2 de 3 TicWatchPro Battery Replacement: étape 16, image 3 de 3
    • Insert an opening pick in the gap between the white plastic frame and the battery.
    • Use the opening pick to pry the battery up and out of its recess.
  17. TicWatchPro Battery Replacement: étape 17, image 1 de 2 TicWatchPro Battery Replacement: étape 17, image 2 de 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
25 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
249 845 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 992 tutoriels rédigés
15 commentaires de tutoriel
What is the battery part number that is required for replacement?
Tim Rhind - Réponse
Thank you!
Saved my ticwatch! Hopefully I get a couple more years out of it!
(Part nr sp452929sf, same for 4g as none 4g watch)
Robin Åström - Réponse
Where did you find this new battery?
Bert Van den Berghe -
No way to get the external screws out. Any advice?
Joan Pujolar - Réponse
Use a T4 bit not a T3 as the directions say. A couple of mine were tight to get out. I put good pressure down on the screw and turned it slowly. I thought for sure I had stripped out the screw head. Using the T4 bit helped immensely.
Jim Bondly -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 56
30 derniers jours : 187
Total : 16,239
