Introduction
This guide shows how to remove and replace the two driveshaft bearings for the Toro Cement Mixer 68009HD.
In order to remove the gear-side bearing, you must remove the driveshaft. This requires removing the tub first. You may be able to extract the pulley-side bearing without removing the driveshaft and tub.
Warning: The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
Ce dont vous avez besoin
Before you begin, press the engine-stop switch to turn off the engine.
Remove the four fasteners securing the engine plate:
Two 14 mm bolts
Two 3/4 inch nuts
Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
Use a crescent wrench to loosen the two set screws on the pulley.
Reassembly tip: The pulley is keyed to install in only one position.
Use a 4 mm hex key to loosen the set screw securing the lock collar.
There should only be one set screw. If the collar isn't loose, check the second hole for set screws.
Pull and remove the pulley-side bearing from its recess.
Lubricate the bearing with some machine oil and set it in place.
Slide the driveshaft into the bearing and tap the gear with a mallet to press the bearing into place.
