Aller au contenu principal
Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement
Ce dont vous avez besoin
  1. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: étape 1, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Safety precautions: étape 1, image 2 de 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 2, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 2, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 2, image 3 de 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 3, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 3, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 3, image 3 de 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 4, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 4, image 2 de 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 5, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 5, image 2 de 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: étape 6, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the tub: étape 6, image 2 de 2
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 7, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 7, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 7, image 3 de 3
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 8, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 8, image 2 de 2
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 9, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 9, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 9, image 3 de 3
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 10, image 1 de 1
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 11, image 1 de 1
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 12, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 12, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 12, image 3 de 3
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
  13. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: étape 13, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the dish: étape 13, image 2 de 2
    • Use a large crescent wrench to remove the bolt securing the dish to the bottom of the yoke.
  14. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 14, image 1 de 1
    • Use a 3/4 inch socket to remove the lock bolt from the yoke.
  15. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 15, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 15, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 15, image 3 de 3
    • The dish is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the dish straight up and remove it from the yoke.
    • A convenient place to set the dish is on top of the removed tub.
  16. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: étape 16, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Reassembly tip: étape 16, image 2 de 2
    • During reassembly, be sure to align the shaft indent with the lock bolt hole as you set the dish in place. Otherwise, you will not be able to properly lock the shaft and tighten the dish bolt.
  17. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: étape 17, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: étape 17, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle: étape 17, image 3 de 3
    • Use a pipe wrench or an extra-large crescent wrench to loosen the dish plug.
    • Remove the dish plug.
  18. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 18, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 18, image 2 de 2
    • The spindle and bearings are very greasy. Handle these components carefully to avoid getting grease everywhere.
    • Push the spindle from the bottom of the dish.
  19. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 19, image 1 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 19, image 2 de 3 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 19, image 3 de 3
    • Pull the spindle from the top of the dish and remove it.
    • After you reassemble the device, make sure to follow manufacturer instructions on how to properly lubricate the device with a grease gun.
  20. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: étape 20, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement, Remove the spindle bearings: étape 20, image 2 de 2
    • Pull and remove the bottom spindle bearing from the bottom of the dish.
  21. Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 21, image 1 de 2 Toro Cement Mixer 68009HD 2018 Spindle Bearings Replacement: étape 21, image 2 de 2
    • Slide the top spindle bearing straight off the spindle and remove it.
Arthur Shi
Membre depuis le 01/03/18
282 244 Réputation
585 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 450 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,271
