Introduction
This guide shows how to remove and replace the spindle for the Toro Cement Mixer 68009HD.
The spindle attaches the tub to the yoke and allows the tub to spin freely.
Warning: The tub and dish are both extremely heavy and require at least two people to lift them. Be sure to practice safe lifting techniques.
Ce dont vous avez besoin
Before you begin, press the engine-stop switch to turn off the engine.
Use a large crescent wrench to remove the bolt securing the dish to the bottom of the yoke.
During reassembly, be sure to align the shaft indent with the lock bolt hole as you set the dish in place. Otherwise, you will not be able to properly lock the shaft and tighten the dish bolt.
Use a pipe wrench or an extra-large crescent wrench to loosen the dish plug.
Remove the dish plug.
After you reassemble the device, make sure to follow manufacturer instructions on how to properly lubricate the device with a grease gun.
