Introduction
If you are experiencing problems when trying to use headphones with the Toshiba Satellite C55-A5140, the headphone (3.5mm) port may need to be replaced. This process involves extensive deconstruction of the device in order to access the motherboard components. Soldering skills will be required to successfully remove the port from the motherboard. If you aren't comfortable with soldering skills please look at this guide to help you with soldering Comment souder et dessouder des connexions. Also note that removing the back of the device will void the warranty.
Ce dont vous avez besoin
Make sure the device is unplugged, completely off, and not warm to the touch.
Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
Flip device over and locate two switches on the back of the device.
Slide switch 1 towards the unlock symbol on the device (switch should click into place).
Slide switch 2 towards the unlocked symbol on the device.
While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
Flip the device over so you see the bottom, and loosen the 5mm PH#1 screw on the L shaped access panel.
