Aller au contenu principal
Toshiba Satellite C55-B5200 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 2, image 1 de 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 6, image 1 de 3 Toshiba Satellite C55-B5200 Keyboard Replacement: étape 6, image 2 de 3 Toshiba Satellite C55-B5200 Keyboard Replacement: étape 6, image 3 de 3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 7, image 1 de 1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: étape 8, image 1 de 2 Toshiba Satellite C55-B5200 Keyboard Replacement: étape 8, image 2 de 2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
2 autres ont terminé cette réparation.
Pablo Andrade
Membre depuis le 02/14/18
1 081 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S3-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 membres
22 tutoriels rédigés
Un commentaire
gracias por la guía
Mark Puga - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 4,054
