Aller au contenu principal
Toshiba Satellite C55-C5268 Heat Sink Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55-C5268 Heat Sink Replacement, Battery: étape 1, image 1 de 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 2, image 1 de 2 Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 2, image 2 de 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Heat Sink Replacement, Back Panel: étape 3, image 1 de 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 4, image 1 de 2 Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 4, image 2 de 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 5, image 1 de 2 Toshiba Satellite C55-C5268 Heat Sink Replacement: étape 5, image 2 de 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: étape 6, image 1 de 2 Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: étape 6, image 2 de 2
    • Unscrew the four 5.0 mm screws holding the heat sink in place using #1 Phillips screwdriver.
    • The 5.0 mm screws can unscrew from the laptop, but stay attached to the heat sink.
    • One of the screws is underneath a ribbon. Be sure to gently move the ribbon out of the way first.
    • Be sure to screw the replacement heat sink in the correct way.
Ben Rounseville
Membre depuis le 10/21/16
471 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 652
