Aller au contenu principal
Toshiba Satellite C855-S5115 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 2, image 1 de 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement: étape 4, image 2 de 2
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite C855-S5115 Keyboard Replacement: étape 5, image 2 de 2
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Claire Fletcher
Membre depuis le 04/05/18
988 Réputation
7 tutoriels rédigés
2 commentaires
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Réponse
Do you have to do anything with the connector before removing?
William - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 33
Total : 2,773
