Aller au contenu principal
Toshiba Satellite L305-S5875 Speakers Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5875 Speakers Replacement, Battery: étape 1, image 1 de 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Speakers Replacement: étape 2, image 1 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 2, image 2 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 2, image 3 de 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: étape 3, image 1 de 3 Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: étape 3, image 2 de 3 Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: étape 3, image 3 de 3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Speakers Replacement: étape 4, image 1 de 1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Speakers Replacement: étape 5, image 1 de 2 Toshiba Satellite L305-S5875 Speakers Replacement: étape 5, image 2 de 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Speakers Replacement: étape 6, image 1 de 2 Toshiba Satellite L305-S5875 Speakers Replacement: étape 6, image 2 de 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Speakers Replacement: étape 7, image 1 de 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  8. Toshiba Satellite L305-S5875 Speakers Replacement, Speakers: étape 8, image 1 de 1
    • Close the laptop and flip it over onto its back.
    • Remove the eleven 6.6 mm Phillips #00 screws along the perimeter and in the center of the laptop.
  9. Toshiba Satellite L305-S5875 Speakers Replacement: étape 9, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 3.7 mm located in the battery compartment.
  10. Toshiba Satellite L305-S5875 Speakers Replacement: étape 10, image 1 de 2 Toshiba Satellite L305-S5875 Speakers Replacement: étape 10, image 2 de 2
    • Flip the laptop back over again, and open the screen as far back as it can go.
  11. Toshiba Satellite L305-S5875 Speakers Replacement: étape 11, image 1 de 2 Toshiba Satellite L305-S5875 Speakers Replacement: étape 11, image 2 de 2
    • Use a spudger, or a clean fingernail to flip up the locking flap—this is the unlocked position.
    • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  12. Toshiba Satellite L305-S5875 Speakers Replacement: étape 12, image 1 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 12, image 2 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 12, image 3 de 3
    • To disconnect, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  13. Toshiba Satellite L305-S5875 Speakers Replacement: étape 13, image 1 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 13, image 2 de 3 Toshiba Satellite L305-S5875 Speakers Replacement: étape 13, image 3 de 3
    • Use the iFixit opening tool to begin removing the cover.
    • After creating enough space, you can use your hands to completely open the cover.
    • Make sure all the screws have been removed before attempting to open the cover, or else the screw threads might strip if too much force is applied.
  14. Toshiba Satellite L305-S5875 Speakers Replacement: étape 14, image 1 de 2 Toshiba Satellite L305-S5875 Speakers Replacement: étape 14, image 2 de 2
    • Open the laptop cover all the way and fold the cover over.
    • Remove the two 3.6 mm Phillips #00 screws from each speaker.
    • Remove the old speakers from the laptop and undo the cable from the cable holders before removing the it all.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Juan
Membre depuis le 01/11/13
109 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 20-5, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 15
Total : 1,962
