Aller au contenu principal
Toshiba Satellite L305D-S5900 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: étape 1, image 1 de 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5900 RAM Replacement: étape 2, image 2 de 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: étape 3, image 1 de 3 Toshiba Satellite L305D-S5900 RAM Replacement: étape 3, image 2 de 3 Toshiba Satellite L305D-S5900 RAM Replacement: étape 3, image 3 de 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Sing Yang Cheng
Membre depuis le 10/20/16
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 246
