Aller au contenu principal
Toshiba Satellite L305D-S5900 RAM Replacement
Anglais
Français
Traduction de l’étape 3
Étape 3
Toshiba Satellite L305D-S5900 RAM Replacement: étape 0, image 1 de 3 Toshiba Satellite L305D-S5900 RAM Replacement: étape 0, image 2 de 3 Toshiba Satellite L305D-S5900 RAM Replacement: étape 0, image 3 de 3
  • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
  • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
  • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
  • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Insérez ici votre traduction
