Aller au contenu principal
Toshiba Satellite L655D-S5095 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 2, image 1 de 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 5, image 1 de 2 Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 5, image 2 de 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 6, image 1 de 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: étape 7, image 1 de 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
5 autres ont terminé cette réparation.
Jerry Wakai
Membre depuis le 01/31/13
377 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-7, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 membres
6 tutoriels rédigés
2 commentaires
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Réponse
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 20
30 derniers jours : 24
Total : 5,021
