Aller au contenu principal
Toshiba Satellite P755 S5390 Touchpad Repair
Ce dont vous avez besoin
  1. Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: étape 1, image 1 de 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: étape 1, image 2 de 3 Toshiba Satellite P755 S5390 Touchpad Repair, Toshiba Satellite P755 S5390 Touchpad Repair: étape 1, image 3 de 3
    • Make sure that your laptop is powered off before starting.
    • Close the cover and turn the laptop over so that the spine is facing away from you.
  2. Toshiba Satellite P755 S5390 Touchpad Repair: étape 2, image 1 de 2 Toshiba Satellite P755 S5390 Touchpad Repair: étape 2, image 2 de 2
    • Slide and hold the locks on both sides of the battery to the unlocked position.
    • Slide and lift the battery out of its compartment.
  3. Toshiba Satellite P755 S5390 Touchpad Repair: étape 3, image 1 de 1
    • Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
    • Keep track of these screws, you will need them in reassembly.
  4. Toshiba Satellite P755 S5390 Touchpad Repair: étape 4, image 1 de 1
    • Turn the laptop back over.
    • Open the cover.
  5. Toshiba Satellite P755 S5390 Touchpad Repair: étape 5, image 1 de 3 Toshiba Satellite P755 S5390 Touchpad Repair: étape 5, image 2 de 3 Toshiba Satellite P755 S5390 Touchpad Repair: étape 5, image 3 de 3
    • Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
    • Do not touch the motherboard.
  6. Toshiba Satellite P755 S5390 Touchpad Repair: étape 6, image 1 de 2 Toshiba Satellite P755 S5390 Touchpad Repair: étape 6, image 2 de 2
    • Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
  7. Toshiba Satellite P755 S5390 Touchpad Repair: étape 7, image 1 de 3 Toshiba Satellite P755 S5390 Touchpad Repair: étape 7, image 2 de 3 Toshiba Satellite P755 S5390 Touchpad Repair: étape 7, image 3 de 3
5 autres ont terminé cette réparation.
Dominic Oldani
Membre depuis le 03/19/16
237 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-20, Lauer Spring 2016 Membre de l'équipe Michigan Tech, Team 1-20, Lauer Spring 2016
MTU-LAUER-S16S1G20
1 membre
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 7
Total : 6,824
