Aller au contenu principal
Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement
Ce dont vous avez besoin
  1. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement, Brakes: étape 1, image 1 de 2 Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement, Brakes: étape 1, image 2 de 2
    • Lean your bike up against a wall or use a bike stand so your bike doesn’t fall over.
    • Remove brake fairing by taking off screw covers and unscrewing both sides.
  2. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 2, image 1 de 1
    • Carefully remove the fairing after the screws are removed.
  3. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 3, image 1 de 1
    • Loosen the brake shoe alignment screw, until it is loose.
    • Then, flip brake shoe over without removing it.
  4. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 4, image 1 de 1
    • Remove the screw from the brake shoe.
  5. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 5, image 1 de 1
    • Remove the brake pad from the brake shoe, by carefully sliding it out.
  6. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 6, image 1 de 1
    • Insert new brake pad into brake shoe.
  7. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 7, image 1 de 1
    • Put the screw back in the brake shoe.
  8. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 8, image 1 de 1
    • Flip brake back over.
    • Align the brake shoe correctly with the wheel's braking surface.
    • Then tighten the outer brake shoe alignment screw.
  9. Trek Speed Concept Triathlon Bike 2018 Brake Pad Replacement: étape 9, image 1 de 1
    • Place the fairing back over the brakes.
    • Then, screw it into place and place screw covers over the screws.
    • Complete steps 3 through 8 for both right and left brakes.
The brakes should be good to go after following this guide. Make sure the brakes work properly before biking to ensure things were tightened enough. If you changed wheels, you need to adjust the brakes so that they grab properly.
Bri Gibson
Membre depuis le 09/23/18
169 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 2,212
