To begin the removal of the circuit board you first need to remove the back cover from the device.
Lift the Leg all the way up and twist the bottom to remove.
Once the bottom part pops out the whole leg should just come off.
Remove any game cartridge from the device.
Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
These covers are made of hard plastic so they may be difficult to remove.
There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
Using a plastic opening tool, detach the backplate from the front piece.
Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
Once the backplate has been removed, you will have access to the circuit board.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
