Aller au contenu principal
VTech InnoTab 2s Screen Replacement
Ce dont vous avez besoin
  1. VTech InnoTab 2s Screen Replacement, Back Panel: étape 1, image 1 de 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Screen Replacement: étape 2, image 1 de 2 VTech InnoTab 2s Screen Replacement: étape 2, image 2 de 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Screen Replacement: étape 3, image 1 de 3 VTech InnoTab 2s Screen Replacement: étape 3, image 2 de 3 VTech InnoTab 2s Screen Replacement: étape 3, image 3 de 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Screen Replacement: étape 4, image 1 de 2 VTech InnoTab 2s Screen Replacement: étape 4, image 2 de 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Screen Replacement: étape 5, image 1 de 2 VTech InnoTab 2s Screen Replacement: étape 5, image 2 de 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2s Screen Replacement, Motherboard: étape 6, image 1 de 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2s Screen Replacement: étape 7, image 1 de 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2s Screen Replacement: étape 8, image 1 de 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2s Screen Replacement: étape 9, image 1 de 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2s Screen Replacement: étape 10, image 1 de 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2s Screen Replacement, Screen: étape 11, image 1 de 2 VTech InnoTab 2s Screen Replacement, Screen: étape 11, image 2 de 2
    • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
    • Remove the front panel from the device to expose the screen.
  12. VTech InnoTab 2s Screen Replacement: étape 12, image 1 de 1
    • Using a heat gun, heat the glue that holds the screen to the rest of the device.
    • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
Esthevan Romeiro
Membre depuis le 10/06/16
261 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 749
