Aller au contenu principal
Visual Land Prestige 7G Battery Replacement
Ce dont vous avez besoin
  1. Visual Land Prestige 7G Battery Replacement, Backplate: étape 1, image 1 de 2 Visual Land Prestige 7G Battery Replacement, Backplate: étape 1, image 2 de 2
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Battery Replacement: étape 2, image 1 de 1
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Battery Replacement: étape 3, image 1 de 2 Visual Land Prestige 7G Battery Replacement: étape 3, image 2 de 2
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Battery Replacement, Battery: étape 4, image 1 de 3 Visual Land Prestige 7G Battery Replacement, Battery: étape 4, image 2 de 3 Visual Land Prestige 7G Battery Replacement, Battery: étape 4, image 3 de 3
    • Use an opening tool to lift the battery from the device.
    • Be careful to not use a metal spudger or tool, as it can bend and harm the battery.
  5. Visual Land Prestige 7G Battery Replacement: étape 5, image 1 de 2 Visual Land Prestige 7G Battery Replacement: étape 5, image 2 de 2
    • Take your soldering gun and carefully remove the red and black wire connecting the battery to the motherboard.
For optimal performance, calibrate your newly installed battery after completing this guide.
Brandon Gray
Membre depuis le 09/13/23
207 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 57
