Aller au contenu principal
Vizio SmartCast Crave 360 Battery Replacement
Ce dont vous avez besoin
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: étape 1, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: étape 1, image 2 de 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: étape 2, image 1 de 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: étape 3, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 3, image 2 de 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: étape 4, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: étape 4, image 2 de 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 1 de 3 Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 2 de 3 Vizio SmartCast Crave 360 Battery Replacement: étape 5, image 3 de 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: étape 6, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: étape 6, image 2 de 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: étape 7, image 1 de 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: étape 8, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 8, image 2 de 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: étape 9, image 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: étape 9, image 2 de 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: étape 10, image 1 de 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: étape 11, image 1 de 1
    • Remove the motherboard from the battery.
2 autres ont terminé cette réparation.
Pavani Lopez Leon
Membre depuis le 09/06/22
433 Réputation
3 tutoriels rédigés
Équipe
Un commentaire
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 46
Total : 1,574
