Aller au contenu principal
WRS315SDHW Icemaker Assembly Replacement
Ce dont vous avez besoin
  1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: étape 2, image 1 de 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: étape 2, image 2 de 3 WRS315SDHW Icemaker Assembly Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: étape 3, image 1 de 2 WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: étape 3, image 2 de 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: étape 4, image 1 de 2 WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: étape 4, image 2 de 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: étape 5, image 1 de 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: étape 5, image 2 de 3 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: étape 5, image 3 de 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: étape 6, image 1 de 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: étape 6, image 2 de 3 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: étape 6, image 3 de 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: étape 7, image 1 de 1
    • Remove the icemaker assembly.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
702 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 28
Total : 308
