Introduction
Follow this guide to remove and replace either of the two shockmounts for the Wacker Compactor Plate VP1550AW 2014.
The shockmounts are easy to access and replace.
Ce dont vous avez besoin
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 3/4" wrench to remove the two nuts securing the handle.
Use your palm to push against the shockmount to prevent it from slipping.
Remove the nuts and washers and retain them for reassembly.
Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
Slide the guide handle down enough to access the shockmounts.
