Aller au contenu principal
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Ce dont vous avez besoin
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: étape 1, image 1 de 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: étape 1, image 2 de 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: étape 2, image 1 de 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: étape 3, image 1 de 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: étape 3, image 2 de 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: étape 4, image 1 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: étape 4, image 2 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: étape 4, image 3 de 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: étape 5, image 1 de 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: étape 6, image 1 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: étape 6, image 2 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: étape 6, image 3 de 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Arthur Shi
Membre depuis le 01/03/18
257 458 Réputation
529 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
141 membres
17 893 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 43
Total : 3,102
