Introduction
Use this guide to replace the auger motor assembly in an older Whirlpool side‑by‑side refrigerator
The auger motor assembly drives the auger which feeds ice to the ice dispenser located on the freezer door.
If the auger motor assembly fails the refrigerator will not dispense ice.
This guide is based on a Whirlpool Model ED5FTGXKQ02 Refrigerator.
Ce dont vous avez besoin
Turn off your main water supply (if connected)
Unplug your device
Pull the handle of the refrigerator door towards you to open it.
Lift the ice maker flap.
Slide the ice maker flap into its slot.
Llift the ice bucket slightly and pull it towards you to remove it.
Use a nut driver to remove the screws securing the auger motor assembly.
Move the auger assembly outward and lower it to rest on the shelf below.
Use your fingers, a spudger, or a small flathead screwdriver to pry and release the tab on the connector.
Pull the auger motor assembly connector straight out to disconnect it.
Repair didn’t go as planned? Ask our Answers community for help.
