Aller au contenu principal
Whirlpool Refrigerator Auger Motor Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: étape 3, image 1 de 2 Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: étape 3, image 2 de 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: étape 4, image 1 de 2 Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: étape 4, image 2 de 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: étape 5, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: étape 5, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: étape 5, image 3 de 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: étape 6, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: étape 6, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: étape 6, image 3 de 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: étape 7, image 1 de 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: étape 8, image 1 de 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: étape 9, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: étape 9, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: étape 9, image 3 de 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: étape 10, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: étape 10, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: étape 10, image 3 de 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: étape 11, image 1 de 1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: étape 12, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: étape 12, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: étape 12, image 3 de 3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: étape 13, image 1 de 1
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: étape 14, image 1 de 1
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: étape 15, image 1 de 2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: étape 15, image 2 de 2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: étape 16, image 1 de 3 Whirlpool Refrigerator Auger Motor Replacement: étape 16, image 2 de 3 Whirlpool Refrigerator Auger Motor Replacement: étape 16, image 3 de 3
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: étape 17, image 1 de 1
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: étape 18, image 1 de 1
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
89 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
45 membres
701 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 68
Total : 1,492
