Aller au contenu principal
Whirlpool Refrigerator Door Seal Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Door Seal Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Door Seal Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Door Seal Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Door Seal Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: étape 3, image 1 de 3 Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: étape 3, image 2 de 3 Whirlpool Refrigerator Door Seal Replacement, Disconnect the door seal: étape 3, image 3 de 3
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: étape 4, image 1 de 3 Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: étape 4, image 2 de 3 Whirlpool Refrigerator Door Seal Replacement, Remove the door seal: étape 4, image 3 de 3
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: étape 5, image 1 de 3 Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: étape 5, image 2 de 3 Whirlpool Refrigerator Door Seal Replacement, Only the door seal remains: étape 5, image 3 de 3
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: étape 6, image 1 de 3 Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: étape 6, image 2 de 3 Whirlpool Refrigerator Door Seal Replacement, Perform a seal test: étape 6, image 3 de 3
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 927 Réputation
88 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
577 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 34
30 derniers jours : 163
Total : 1,688
