Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Whirlpool Refrigerator Door Sensor Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: étape 1, image 1 de 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: étape 1, image 2 de 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: étape 1, image 3 de 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: étape 2, image 1 de 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: étape 2, image 2 de 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: étape 2, image 3 de 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: étape 3, image 1 de 2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: étape 3, image 2 de 2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: étape 4, image 1 de 2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: étape 4, image 2 de 2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 987 Réputation
89 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 135
Total : 4,431
