Aller au contenu principal
Whirlpool Refrigerator Temperature Control Board Replacement
Ce dont vous avez besoin
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: étape 1, image 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: étape 2, image 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: étape 2, image 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: étape 2, image 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: étape 3, image 1 de 2 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: étape 3, image 2 de 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: étape 4, image 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: étape 4, image 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: étape 4, image 3 de 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: étape 5, image 3 de 3
    • Disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: étape 6, image 1 de 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: étape 7, image 3 de 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: étape 8, image 1 de 1
    • Pull the temperature control board straight out of its housing to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membre depuis le 04/14/15
15 945 Réputation
89 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 42
Total : 1,938
