Introduction
Use this guide to replace the water filter housing in your Whirlpool Refrigerator.
The water filter housing stores the water filter and connects it to the water inlet valve assembly.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Ce dont vous avez besoin
Pull the front panel straight off the chassis and remove it.
Remove the screw(s) securing the water filter housing.
Remove the screw(s) securing the wire harness grounding wire.
Pull the housing out of the chassis enough to access its left-hand water connections.
Place a clean and dry rag under the water hoses.
Use needle nose pliers, or your fingers, to remove any clips on the top and bottom water hose.
Compress the plastic ring near the end of the water hose.
While compressing the ring, pull the hose away from the ring to disconnect it.
Repeat for the other water hose.
Repair didn’t go as planned? Ask our Answers community for help.
