Aller au contenu principal
Wiko Getaway Screen Panel Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Wiko Getaway Screen Panel Replacement, Back cover: étape 1, image 1 de 3 Wiko Getaway Screen Panel Replacement, Back cover: étape 1, image 2 de 3 Wiko Getaway Screen Panel Replacement, Back cover: étape 1, image 3 de 3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: étape 2, image 1 de 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: étape 2, image 2 de 3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: étape 2, image 3 de 3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: étape 3, image 1 de 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: étape 3, image 2 de 3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: étape 3, image 3 de 3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: étape 4, image 1 de 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: étape 4, image 2 de 3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: étape 4, image 3 de 3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: étape 5, image 1 de 3 Wiko Getaway Screen Panel Replacement, Final: étape 5, image 2 de 3 Wiko Getaway Screen Panel Replacement, Final: étape 5, image 3 de 3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
4 autres ont terminé cette réparation.
Alexandre Isaac
Membre depuis le 04/07/13
2 887 Réputation
8 tutoriels rédigés
Équipe
The Repair Academy Membre de l'équipe The Repair Academy
Business
1 membre
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 2,112
