Ce dont vous avez besoin
Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
