Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox Thomson DVD Drive Disassembly
Ce dont vous avez besoin
  1. Xbox Thomson DVD Drive Disassembly, Hard Drive: étape 1, image 1 de 1
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox Thomson DVD Drive Disassembly: étape 2, image 1 de 1
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
    Demander à FixBot
  3. Xbox Thomson DVD Drive Disassembly: étape 3, image 1 de 2 Xbox Thomson DVD Drive Disassembly: étape 3, image 2 de 2
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    Demander à FixBot
  4. Xbox Thomson DVD Drive Disassembly: étape 4, image 1 de 1
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
    Demander à FixBot
  5. Xbox Thomson DVD Drive Disassembly: étape 5, image 1 de 2 Xbox Thomson DVD Drive Disassembly: étape 5, image 2 de 2
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
    Demander à FixBot
  6. Xbox Thomson DVD Drive Disassembly: étape 6, image 1 de 2 Xbox Thomson DVD Drive Disassembly: étape 6, image 2 de 2
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
    Demander à FixBot
  7. Xbox Thomson DVD Drive Disassembly: étape 7, image 1 de 2 Xbox Thomson DVD Drive Disassembly: étape 7, image 2 de 2
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
    Demander à FixBot
  8. Xbox Thomson DVD Drive Disassembly: étape 8, image 1 de 3 Xbox Thomson DVD Drive Disassembly: étape 8, image 2 de 3 Xbox Thomson DVD Drive Disassembly: étape 8, image 3 de 3
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
    Demander à FixBot
  9. Xbox Thomson DVD Drive Disassembly: étape 9, image 1 de 2 Xbox Thomson DVD Drive Disassembly: étape 9, image 2 de 2
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
    Demander à FixBot
  10. Xbox Thomson DVD Drive Disassembly, Disc Drive: étape 10, image 1 de 3 Xbox Thomson DVD Drive Disassembly, Disc Drive: étape 10, image 2 de 3 Xbox Thomson DVD Drive Disassembly, Disc Drive: étape 10, image 3 de 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
    Demander à FixBot
  11. Xbox Thomson DVD Drive Disassembly: étape 11, image 1 de 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
    • If you are removing the disk drive in order to gain access to the motherboard underneath, you do not need to remove the plastic housing.
    Demander à FixBot
  12. Xbox Thomson DVD Drive Disassembly, Remove Screws & Housing: étape 12, image 1 de 2 Xbox Thomson DVD Drive Disassembly, Remove Screws & Housing: étape 12, image 2 de 2
    • Remove two #1 PH screws
    • Remove upper metal housing
    • Remove two T10 Screws
    • Remove lower metal housing
    Demander à FixBot
  13. Xbox Thomson DVD Drive Disassembly, Drive PCB: étape 13, image 1 de 2 Xbox Thomson DVD Drive Disassembly, Drive PCB: étape 13, image 2 de 2
    • Remove two PH1 screws
    • Gently pull up on the ribbon retaining tab. Do NOT pull on ribbon. It will slide itself out in final step
    • Orange/Yellow steps only required if you need to remove the entire PCB
    • Gently pull up on the ribbon retaining tab. Ribbon is attached to underside of PCB via a sticky pad. Gently pull the ribbon away from pad
    • Desolder both points. Red (Left) Black (Right)
    • Gently press up on the PCB where you removed the two PH1 screws and rotate the board upside down
    • If your drive is "dead" this is where I would suggest replacing your electrolytic capacitors. There are 12 on the Thomson drive
    Demander à FixBot
  14. Xbox Thomson DVD Drive Disassembly, Manually Eject Drive: étape 14, image 1 de 3 Xbox Thomson DVD Drive Disassembly, Manually Eject Drive: étape 14, image 2 de 3 Xbox Thomson DVD Drive Disassembly, Manually Eject Drive: étape 14, image 3 de 3
    • With the drive upside down slide the white lever to the right
    • Drive door will eject about a half inch
    • Flip the drive over and slowly pull the door out
    • Don't forget to slide the white lever back to the left during reassembly
    Demander à FixBot
  15. Xbox Thomson DVD Drive Disassembly, Apply Grease & Clean Laser: étape 15, image 1 de 2 Xbox Thomson DVD Drive Disassembly, Apply Grease & Clean Laser: étape 15, image 2 de 2
    • These drives are seasoned. Model 1.0 Xboxes were made in 2001 and nearly 20yrs old now. It's wise to re-lubricate them anywhere moving parts or friction is applied
    • If your drive door sticks when pressing the eject button, now is the time to replace your drive belt. Do this before applying grease to eliminate accidentally getting it on your belt
    • Apply grease to highlighted areas
    • Don't forget the tooth track, highlighted yellow, shown in previous step
    • Apply a liberal glob of grease along the tooth track and insert/withdraw the drive door a few times to easily lubricate the gears highlighted pink
    • With a cotton swab, gently clean your laser with 91% or higher isopropyl alcohol
    Demander à FixBot
3 autres ont terminé cette réparation.
Navy Vet 2015
Membre depuis le 06/25/15
8 267 Réputation
15 tutoriels rédigés
3 commentaires de tutoriel
What is the plastic disk at the top of the drive above where the dvd sits is called?
Austin Perdue - Réponse Partager
can it cause error 12 even if it opens drive? talking 1st gen xbox i also move the laser am not sure if i need to realign the spinning disc or both?
laser did get clean but even with opening drive gets error 12….
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 48
30 derniers jours : 274
Total : 9,215
