Introduction
Use this guide to replace the charging port located inside your ZTE Lever Z936L if it is malfunctioning or is broken.
Please verify that your device does indeed need the charging port replaced by checking to see that the device does not charge when plugged in.
Before beginning, make sure you that the device is powered off or has no charge. Also make sure to have nothing connected to the device as well which means making sure to remove the sim and SD cards if you have them.
Ce dont vous avez besoin
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Disconnect the power button from the motherboard with a plastic opening tool.
Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
Use a soldering gun to desolder the two points connecting the charging port to the motherboard.
