Aller au contenu principal
ZTE Lever Power Button Replacement
Ce dont vous avez besoin
  1. ZTE Lever Power Button Replacement, Battery: étape 1, image 1 de 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Power Button Replacement: étape 2, image 1 de 2 ZTE Lever Power Button Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Power Button Replacement: étape 3, image 1 de 2 ZTE Lever Power Button Replacement: étape 3, image 2 de 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Power Button Replacement: étape 4, image 1 de 2 ZTE Lever Power Button Replacement: étape 4, image 2 de 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Power Button Replacement: étape 5, image 1 de 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Power Button Replacement, Volume Buttons: étape 6, image 1 de 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Power Button Replacement: étape 7, image 1 de 3 ZTE Lever Power Button Replacement: étape 7, image 2 de 3 ZTE Lever Power Button Replacement: étape 7, image 3 de 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Power Button Replacement: étape 8, image 1 de 2 ZTE Lever Power Button Replacement: étape 8, image 2 de 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Power Button Replacement: étape 9, image 1 de 2 ZTE Lever Power Button Replacement: étape 9, image 2 de 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Power Button Replacement, Power Button: étape 10, image 1 de 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Power Button Replacement: étape 11, image 1 de 2 ZTE Lever Power Button Replacement: étape 11, image 2 de 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
Michael Gonzalez
Membre depuis le 01/29/18
501 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S5-G2, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 210
