Aller au contenu principal
ZTE Max XL Display Replacement
Ce dont vous avez besoin
  1. ZTE Max XL Display Replacement, Display: étape 1, image 1 de 2 ZTE Max XL Display Replacement, Display: étape 1, image 2 de 2
    • Before disassembly, assure the phone is powered off.
    • Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
  2. ZTE Max XL Display Replacement: étape 2, image 1 de 1
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide
    • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Display Replacement: étape 3, image 1 de 3 ZTE Max XL Display Replacement: étape 3, image 2 de 3 ZTE Max XL Display Replacement: étape 3, image 3 de 3
    • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
    • There are 3 tabs on top and bottom and 6 on each side.
  4. ZTE Max XL Display Replacement: étape 4, image 1 de 2 ZTE Max XL Display Replacement: étape 4, image 2 de 2
    • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
  5. ZTE Max XL Display Replacement: étape 5, image 1 de 1
    • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
  6. ZTE Max XL Display Replacement: étape 6, image 1 de 1
    • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
  7. ZTE Max XL Display Replacement: étape 7, image 1 de 1
    • Use an opening tool between the screen and side trim battery cover to remove the screen.
  8. ZTE Max XL Display Replacement: étape 8, image 1 de 2 ZTE Max XL Display Replacement: étape 8, image 2 de 2
    • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
  9. ZTE Max XL Display Replacement: étape 9, image 1 de 2 ZTE Max XL Display Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Using the iFixit opening tools carefully pry the edge of the battery away from the casing.
    • Do not bend or puncture the battery during this process.
    • If the battery does not lift away freely, use careful amounts of isopropyl alcohol to help soften the adhesive. Gently work a thin opening pick or plastic card along the underside of the battery, pushing the card through the adhesive while lifting the battery free.
  10. ZTE Max XL Display Replacement: étape 10, image 1 de 1
    • After taking off the battery and disconnecting all the metal tabs underneath, using the iOPener to break the adhesive between the display and the circuit.
  11. ZTE Max XL Display Replacement: étape 11, image 1 de 2 ZTE Max XL Display Replacement: étape 11, image 2 de 2
    • Use the plastic opening pick in the iFixit kit to wedge between the display and circuit.
    • Be sure not to damage the wire connecting the display to the circuit.
    • Replace the display and resemble the device following the reverse order
4 autres ont terminé cette réparation.
Isaac Ssaku
Membre depuis le 04/11/22
293 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-2, Harley Spring 2022 Membre de l'équipe IUPUI, Team 1-2, Harley Spring 2022
IUPUI-HARLEY-S22S1G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 141
