Aller au contenu principal
bObi Robotic Vacuum Screen Replacement
Ce dont vous avez besoin
  1. bObi Robotic Vacuum Screen Replacement, Top Cover: étape 1, image 1 de 2 bObi Robotic Vacuum Screen Replacement, Top Cover: étape 1, image 2 de 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Screen Replacement: étape 2, image 1 de 3 bObi Robotic Vacuum Screen Replacement: étape 2, image 2 de 3 bObi Robotic Vacuum Screen Replacement: étape 2, image 3 de 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Screen Replacement: étape 3, image 1 de 3 bObi Robotic Vacuum Screen Replacement: étape 3, image 2 de 3 bObi Robotic Vacuum Screen Replacement: étape 3, image 3 de 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Screen Replacement: étape 4, image 1 de 3 bObi Robotic Vacuum Screen Replacement: étape 4, image 2 de 3 bObi Robotic Vacuum Screen Replacement: étape 4, image 3 de 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Screen Replacement, Screen: étape 5, image 1 de 2 bObi Robotic Vacuum Screen Replacement, Screen: étape 5, image 2 de 2
    • Remove the four screws that secure bObi's screen and lift the whole piece out.
    • Put the replacement screen in the open space.
  6. bObi Robotic Vacuum Screen Replacement: étape 6, image 1 de 2 bObi Robotic Vacuum Screen Replacement: étape 6, image 2 de 2
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
Chelsea
Membre depuis le 09/24/14
2 278 Réputation
31 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 6
Total : 166
