Introduction
You can install hard drives up to 9.5mm thick.
Outils
Pièces
Aucune pièce nécessaire.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 12 mm Phillips in the lower right corner.
Four 14.5 mm Phillips.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips.
Two 4 mm Phillips.
Remove the four Phillips screws securing the hard drive to the metal framework.
Remove the following three 3 mm Phillips screws from the metal AirPort card retaining bracket.
Lift the metal AirPort card retaining bracket up and out of the computer.
Remove the hard drive brackets from the left and right sides of the hard drive.
Annulation : je n'ai pas terminé ce guide.
75 autre(s) ont terminé cette réparation.
Pièces jointes
5 commentaires
Wow!! Who knew it would be so complicated?!? I just wanted to pull the hard drive out before recycling the old case and never would have figured it out on my own. Thanks so much for posting these instructions.
A lot of these steps aren‘t necessary. Especially to save yourself the trouble: do not disconnect the power button and speaker-it works fine with having the shield next to the iBook with the cables still threaded through the metal sheet.
