Aller au contenu principal
iFixit Side Stack Retail Display Assembly
Ce dont vous avez besoin
  1. iFixit Side Stack Retail Display Assembly, Empty Box Components: étape 1, image 1 de 1
    • Box should include:
    • Set of screws/driver
    • Metal rods
    • Honeycomb Base/Feet
    • Main stand (back/sides)
    • Two large, one small foldable shelf insert
    • Two large, one small black rectangular insert
    • "You can fix it" panel and iFixit topper (not pictured)
  2. iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: étape 2, image 1 de 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: étape 2, image 2 de 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: étape 2, image 3 de 3
    • The three angled supports fit into the two rectangular supports.
    • Place the fully constructed honeycomb base into the display.
  3. iFixit Side Stack Retail Display Assembly, "You can fix it": étape 3, image 1 de 3 iFixit Side Stack Retail Display Assembly, "You can fix it": étape 3, image 2 de 3 iFixit Side Stack Retail Display Assembly, "You can fix it": étape 3, image 3 de 3
    • Fit “You can fix it” panel over front of honeycomb base
    • “You can fix it” panel sides fit INSIDE of base walls
    • Use screws to fasten
  4. iFixit Side Stack Retail Display Assembly, Build Shelf Insert: étape 4, image 1 de 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: étape 4, image 2 de 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: étape 4, image 3 de 3
    • Build bottom shelf, using one of two larger foldable shelves
    • Tabs fit together, fit side tabs along back, then fold over and secure
  5. iFixit Side Stack Retail Display Assembly, Install Metal Supports: étape 5, image 1 de 2 iFixit Side Stack Retail Display Assembly, Install Metal Supports: étape 5, image 2 de 2
    • Install two metal support for middle shelf
    • Metal rods fit into provided holes
  6. iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: étape 6, image 1 de 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: étape 6, image 2 de 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: étape 6, image 3 de 3
    • Fit bottom shelf into bottom shelf slots cut into back of display
    • Tabs go out the back and then back in towards the front
    • Lay black shelf insert into shelf
    • Fit screws together to hold shelf in place
    • Repeat for middle and top shelves
    • Top shelf and insert are smaller than bottom and middle shelves
  7. iFixit Side Stack Retail Display Assembly, Fold Sides into Honeycomb Base: étape 7, image 1 de 1
    • Like so.
    • (Go Angels!)
  8. iFixit Side Stack Retail Display Assembly, iFixt Header Sign: étape 8, image 1 de 2 iFixit Side Stack Retail Display Assembly, iFixt Header Sign: étape 8, image 2 de 2
    • Fold top section down to make holes match
    • Align iFixit sign and install using screws
Eric Essen
Membre depuis le 06/04/10
17 894 Réputation
8 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 448 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 297
