Introduction
Use this guide to replace the iSight camera.
Pièces
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the iSight camera cable.
Remove the two 4.3 mm T5 Torx screws securing the camera board to the top of the rear enclosure.
